Building said:It's an LG. The power On and Off work when the remote is in the TV mode, just not for the combo button when in DTV mode.
Lanarian said:Usually, this happens when you have the wrong code, even tho the volume works. Try another code for the TV and follow this procedure: Enter new code, try Volume control-if it works slide the switch back to the left and try the off and on buttons, if they work on both the receiver and the TV, your done, if they dont, try another code and repeat.
Sorry, I've been golfing tonight. When i got home, I retried most All of the codes and finally got one to do everything. This is a remote I had programmed earlier on a different box about 2 years ago. It is also set up for RF and I already have a second RF remote working another TV from the same box. I know I'm rambling on now, but thanks for the help! I did just need to keep trying all the codes to get everything to work for this TV.
