parp said:You need a signal combiner, something like the Eagle Aspen Super Home Node.
http://www.starlink-dss.com/SHN24.htm
sdsumann said:Ok here is a diagram of how I would want to do it. Basically I am adding a winegard antenna in my attic of a two story home. I am not hooked up to the cable infastructure and would be broadcasting on channel 80 (or whatever i set up the rf out of the 522 to be). Although it is not recomended is it possible?
I am sorry I am at work and only have access to word, sorry for the limited drawing
sdsumann said:right now the 522 output is above the uhf range. channel 79 I think setup as catv. where would I get an inline unidirectional amp? I have ordered the 8 bay uhf antenna from solidsignal and its coming on Monday.
I will really throw you for a loop if the above was possible...can you add a dish 1000 on the same line? then use a dish separator at the other end? and how and where would i insert the dish 1000 feed?
The reason i ask is i eventually am going to get the AT&T Homezone box (labeled as 622 to get further help) (if it ever comes out) and am trying to set up everything now for that.
