I will have dish installed on next monday. One of the receivers is 522. I currently have 3 connections at the location of 522. Two of them from external wall (previous directv installation), and I will use them as the dual satellite feeds. The third connection is the existing cable wiring inside house, so I can use it to backfeed the TV2 output of 522 to the entire house. My question is can I use the same cable wiring of the third connection to feed the antenna signal to 522? Is it possible to combine incoming antenna signal with the output of TV2 of 522 on a single cable?
Thanks a lot
Jeff
Thanks a lot
Jeff
