I currently have a Dish service with a dish pro plus antenna, everything works great. I can get local channels if i hook up another antenna and point it at 148. I have my old Directv antenna from 4-5 years ago. I tried to use this to bring in my 148, it did not work... I did some research and found out the DPP only works with Pro LNBF's and the Directv is similar to a legacy. My question is; Can I use an old dish pro dual lnb mounted on my directv antenna to bring in 148? The DP LNB is suppose to work but i don't know if it will work mounted on the directv antenna...
If this works all i need to do is buy the Y-adapter for $10-$12 instead of purchasing a whole new DP setup.
Thanks, ScottOz
Thanks, ScottOz
