OTHER Cisco D9854 analog audio output How do I connect
ken2400
1,309
144
Central NY State
Cisco d9854 audio output
I know this not FTA stuff but how does one get analog audio output from one of these receivers?
I see there is a screw sets for left and right BUT it has three outputs for each. Do I bother with ground?
I have antenna TV working without audio output.
If using a balanced input (one the other end) you'd use the + and -,
The GND can usually be ignored, but if hum is heard, connect it also.
if going into an unbalanced load, use the + and ground. (on each channel)
Openbox s9/s10 mass channel delete
AZBOX AZBox Me FIRM 1.84
