Read all 3 posts before you do anything listed in here.
I used a DSR-921 receiver for this test. The DSR-921 is a Canadian version of the 920 receiver.
The 921 was slaved to one of my other receivers which was on W5-700 at the time.
A master reset was done (options-6-7-7-8) then the key for a master reset was hit.
After rebooting the receiver and going to the reset sat limits I then programmed in all the available satellites that were there. They were as follows.
S2 - G6 - S3 – T4 – G7 – X7 – G3 -
T5 – G4 – S4 – W1 – A2 – E2 – M1 –
M2 – G9 – G5 – C3 – G1 – C4 – C1
Since W5 was not on the list I tuned to G9-18 on the 921 receiver since that was on my list of available satellites to choose from.
After a minute or two the 921 received a digital lock on G9-18 and a few minutes later the screen blinked a couple of times. When it did this the receiver no longer was showing G9 but it was now showing (G0).
Channel count from (options- 6-5) after a master rest was 490
The TDT count from Diagnostic screen G (options- 6- 0-5) and use the arrow key on the remote to go to "Diagnostic screen G" top line 5th set of numbers on the top line reading from the left was (520)
After a few more minutes the channel count went up to 719
Using (options- 6-4-4) I noticed that Satellite X0 was added and G9 was added.
Leaving the main receiver on W5 the slaved 921 did not have any other satellite map changes. Not even the W5 satellite was in the receiver.
Continued on next post:
