Changing remote address on a 501 DVR without the remote...
skyfreedom
6
I recently bought a Dishnetwork 501 DVR receiver from a friend but he did not have the remote.
I use a MX850 remote and I need to change the remote address on the 501 from 1 to 3. Is this possible without the remote?
Thanks everyone
Thanks everyone
Skyfreedom,
I don't believe it can be done without the Dish remote. Most Non Dish brand remotes will only work when the remote address of the receiver is set to one.
If you set the receiver to factory defaults then the remote addess will go back to remote address one.
Without a remote that completely simulates a dish Remote I don't think you can change the remote address without the Dish remote.
The process of changing the remote address is very simple, pull up the system information screen. Set the remote address you wish to use in the Actual Remote control, then press the "RECORD" button on the remote, thats it you are done.
With all that said I don't believe it can be done without the DISH remote and I don't believe any Off brand remotes will support a receiver using anything but Remote address "01".
John
great idea
So if I change the receiver to defaults it should change the remote address to 1, correct?
How do I go about setting the receiver to factory defaults?
Thanks for the everyone
The sequence is menu 6-1-6. Connect the receiver to a TV and push the buttons on the front of the receiver.:)
Scramble Channels
Superdish vs. 2 dishes for locals
