Happy Ending...I finally got my system working in the RV. With the dome satellite's single LNB as you know you can only get one sat at a time. With some patience, (not pressing buttons too fast from impatience) I was able to lock on to 110. (Thanks Chad for the Dish Pointer app advice) I knew my dish was pointing at 110 but because it is mechanized you have to rely on it to be correct. You cannot move it or set it manually. That being said using the Dish Pointer I was convinced I was at or near 110. Being patient it locked on and then the check switch went to 1-38 both tv1 and tv2, (not 1-1 like before, apparently starting to get a signal).
Again, I patiently waited for the system to finish and when it did, it stated, "you have fewer satellites, do you want to save or cancel". I saved. This made 110 the only sat coming through the receiver. I believe what happened next is that the system (my 311k receiver in the RV) was stretched and having problems trying to capture two different satellites, very warm/hot to the touch.
Once I saved just 110 sat only, then everything loaded just like the house and I received the program guide and all of the channels (transponders) on 110 that are my subscription, even the local OTA that we get with our subscription nice and clear.
After dinner, I turned everything on again, the TV and the Dish receiver and all of the programs were there, no down loading, came right up.
I was beginning to think maybe my dome LNB or circuit board were beginning to fail. I did notice the receiver was very warm, but it seem more normal after dinner, possibly because it was straining to read or get signal. Tonight I disconnected the 120 volt plug on the receiver, don't want a fire and will recheck programming in the morning. Also tomorrow I may do another check switch to see if tv2 is no longer showing.
Thanks again...everybody and I hope some other RV'er gains from my experience....(now back to programming a UHF remote....LOL)
