Cband questions
fj45lvr
12
Ok I resurrected my old dish with a newer IRD (dsr-922). What I want to know now is LyngSat the place that most look at to see what channels are available?? the 922 will get the non-scrambled analog and then only the DC II that is also non-scrambled and NO DVB is that Correct??? The DVB would only be available with a FTA reciever like a Pansat hooked up as a slave???
Also if you subscribe to a vc2+ or DCII movie channel can you record the movies with a vcr or dvd recorder???
How do you guys lube your actuator arm?? I seem to find myself having to retune the satellites frequently and am assuming that the pulses are not accurate or I am a little sticky?
Should I be able to get SBS 6 (74w)?
Are c-band LNBs especially prone to drift?
