I really don't like 211z's.
I completely agree. The 211z is so frustrating. I was not happy when they started using these instead of the 211k. The 211k has been a fantastic receiver.
I had this error too a while back. I realized that I had my TV set up as a monitor using the PC setting on the TV rather than the Satellite setting on the TV. When I put the TV into Satellite rather than PC, the problem went away. I wonder if you may have the same problem that I did.
What do you mean by "PC and Satellite setting" ? Are you referring to the inputs?I had this error too a while back. I realized that I had my TV set up as a monitor using the PC setting on the TV rather than the Satellite setting on the TV. When I put the TV into Satellite rather than PC, the problem went away. I wonder if you may have the same problem that I did.
That's not making it any clearer.I think it not the input but the source.....
Let's see if I can make it bit clearer. Most newer TVs have, in their menu settings, a way to tell the TV what your source signal is. As an example, my Sharp shows, the following: Auto, Standard, Movie, Game, PC, User, Dynamic, Dynamic (Fixed). If the OP was, perhaps, set to PC the TV would make adjustments as if a PC was the source.
I have to go along with your assessment.That's a little more helpful. Input and source are basically the same thing. Sounds like you're just talking about the video settings. If that's the case I wasn't aware that changing those settings could make a difference.
It shouldn't affect HDCP at all. As Schermann points out, those settings are usually for the picture/image.It does make a difference on my LG TV. If I pick "Computer" as my source for a given input certain selections on the TV menu regarding that input are different than if I tell it something else as being the source. I don't know if HDCP would be affected or not, but for instance the setting to smooth the picture during fast scenes will not work in Computer mode. Picking "Notebook" changes how I can pick the screen size. (Maybe other settings not sure)
That sounds more like a "mode" setting, as "source" typically means the same as "input" in video terminology.Let's see if I can make it bit clearer. Most newer TVs have, in their menu settings, a way to tell the TV what your source signal is. As an example, my Sharp shows, the following: Auto, Standard, Movie, Game, PC, User, Dynamic, Dynamic (Fixed). If the OP was, perhaps, set to PC the TV would make adjustments as if a PC was the source.
Or maybe it bypasses the handshake altogether to allow for the shorter input lag.Computer mode also changes the input lag, makes the lag less and is meant for gaming. I don't know if that timing change would cause errors in the handshake.
The acid test will be for Dirt to get you a replacement, and if a No Go, it's the Vizio. But as mentioned before, ask for a 211k so if it is the TV, you can connect via component.
Honestly, gave up explaining that. I will say this just to kill the idea. The system, it has no way to input specific receivers. It only inputs family models. ie solo hd non dVR, or duo hd dvr, or hopper, or hopper with sling(they may have since removed the option for the hopper). Nowhere does it say "would you like a 211, a 211k, or a 211z"There is absolutely no way, even through DIRT, to guarantee that the OP will get a 211k. The board has gone round and round on this, more than a few think I am wrong about this, and that's fine, but I'm telling folks, there simply is no way to specify what model of 211 a customer will receive. I have had to deal with issues like this. A customer had a 311 that had the interactive capability, and a coax output, and the customer was migrated to the 211, and got a 211z. I told 'em, I cannot replace and be sure a 211k will arrive. They called back, and an offshore agent set up a receiver change (which would require a commitment) to get them a 211k. I checked later, it didn't work.
The only way to really be sure someone gets a specific model receiver is through a reseller or retailer, where they have them in inventory.
