Cancelled Service
BruceE
80
I have cancelled my Dish service & received the boxes to return the receivers back to them. The paperwork inside the boxes call for a switch to be returned. I can not find where I have a switch. Can anyone tell me where to look? What to do if you do not have a switch?
Thank you,
Bruce
Follow your coax lines from your dish, till you run into a box with several coax's hooked up.
You'll be fine if all you returned were the receivers. If you have 3 or less receivers, or 2 or less hoppers you likely do not even have a switch. It's built into the LNB.
Reactions: KE4EST
HopperGo Reset Button On Unit
