Can you use one cellular signal booster to cover five buildings? That question came through our social channels and it seemed like a good one for a blog article. The answer, as they say on TV, may surprise you.
You can use something like this WilsonPro Enterprise 4300 and put the antennas in four different buildings. You can even use a splitter to add a fifth antenna if you want. It’s one of the most powerful and advanced cellular signal boosters ever made and gives you a lot of options for boosting signal in a large area.
In order to get signal to five separate buildings, you’re talking about a lot of cable. You’re possibly burying it or running it through underground conduits. That means it’s hardly going to be a straight shot from building to building. The problem is, you’re adding a lot of cable.
The more cable you add, the less signal gets where you need it to be. Eventually you get to the point where the amount of cable you’ve used weakens the signal enough that there isn’t any benefit to the booster at all. If the five buildings in question are fairly close and connected by catwalks or conduits, perhaps it could work. Chances are if they’re relatively far away, it won’t.
There are options that let you use fiber interconnects inside buildings. If budget isn’t a factor, this is definitely the better way to go. Fiber has almost no loss and it’s possible to have literally miles between buildings and still have one booster that controls it all. However, in the real world budget is almost always a factor. A fiber-based solution is going to be quite a bit more expensive. It’s not just the fiber itself. In fact optical fiber isn’t any more expensive than copper-based cable. It’s the encoders that change from coaxial to optical and back again. That’s, as they say, where they get you.
The best option is going to be planning a system with multiple boosters that puts strong signal where you want it to be. I get it, this is probably going to cost more money. But the bottom line there is, it’s going to work.
Luckily, you have a friend in your corner. The experts at Signal Connect can help you plan a cellular signal booster system that works the way you want it to. Based on your plans and blueprints, and a little bit of information about how the cell signal is outside, they can come up with a personalized estimate that’s going to make it easy for you to get the cell service you want.
What are you waiting for? It all starts with a call to 888-233-7563 where experts are standing by during East business hours. We have an enterprise team ready to take on challenges like this one. While you’re on the phone with them, remember to talk about all the other services Signal Connect offers. We can help turbocharge your business with better internet service, security, phones, enterprise asset management, and of course live television service. We’re here for whatever you need!
All it takes is one call. Call now, or if it’s after hours, fill out the form below. We’ll get right back to you!
The post Can you use 1 booster for 5 buildings? appeared first on The Solid Signal Blog.
Continue reading...
Yes you can do it.
But, do you want to?
A better option
Continue reading...
