Cabling Help Needed
oddbody
Memphis
Hey guys, new member here..
I've got a single LNB system with a multiswitch. Running out of ports and too cheap to go to dual LNB. I've got two DVRs and guess I need two feeds into each so I can watch and record at the same time.
Instead of running two new RG11 runs to each receiver, and I don't think I have enough ports left on the multiswitch, is there some kind of mux I can run off the single existing coax going to the existing recievers and emulate two separate feeds into the receivers?
I know this must be a simple question that you guys come across all the time. Your sage advice would be greatly appreciated! What's your recommendation?
Oddbody:yikes
More information is needed. What multiswitch do you have?
What model DVRs?
Let's take a guess here. Your single LNB dish actually has two outputs which is connected to a 2x4 multiswitch. Which should be enough for your 2 DVRs. You will need to have two lines run from the multiswitch to each DVR.
Are you trying to add more DVRs? And what models are they?
You can't "mux" a single line to get more. You'd need to get a larger multiswitch.
KING TV Seattle
Unreasonable Customer Rants
