Cablevision Boost Now available in my area.. Questions
Sean Mota said:
http://www.optimumonline.com/index.jhtml?pageType=boost_landing
Since it is available in my area isn't the speed to go to 15mbp free of charge?
Boost is the 30/2 package from Cablevision. Everyone, at least according to CV, now has 15/2 speeds, since the speeds were upped to compete with FIOS. Too bad CV can never touch the 5Mbps upload of FIOS, which I miss. You have to sign up for Boost and pay more per month, I think $14.95/month if you don't have OV, and $9.95/month if you have OV. But yes, you should be getting 15 Mbps speeds or close to, 12-14 Mbps. You may have an older modem and need to replace it:
Modems Compatible with enhanced speed, Standard Optimum Online Service
Motorola SBV5120
Motorola SB5100
Scientific-Atlanta DPC2100
Scientific-Atlanta DPX2203
Motorola SBV4200
Motorola SBV4501
Motorola SB4200
Modems Compatible with Optimum Online Boost service
Motorola SBV5120
Motorola SB5100
Non-compliant modems
Motorola SB4100
Motorola SB3100
Modems manufactured by 3Com, RCA, TCE, Terayon, Thompson and Toshiba
I will check the modem model but I am sure I've got one of the new ones. I checked the connection on a wireless connection last night and it was like 5mbps download and 1.5 mbps upload. I used this http://www.speakeasy.net/speedtest/
to check the speed. Maybe I should take my laptop to the actual modem and make a connection and check the speed from there.
It could also be your router some older routers have a 10mbps wan port while the newer ones have a 10/100mb[s wan port. Since your getting more the 1mbps upload I would lean toward the router. Also if your connecting wirelessly your will also see a drop in speed.
I checked at the modem and router and I am getting about 10mbps. Not quite the 15mbps or 12-14 promised by CV. I have the Motorola SBV5120 modem so I should have been able to get something closer to 12 but no cigar.
Any other thoughts why? Should I call CV and ask why?
On a separate note my wireless is killing me. With wireless I only 4-5 mbps. Anyway, at the modem I am getting less than the 12-14 mbps. Anything else I can do?
Old Technology- slightly off topic
New Test Channel in Tampa Bay
