cable lenght from receiver to tv?
all4jo
394
9
Haiti and lexington ky
hello everyone, i wanted to know what is the maximun lenght of rg6 cable that i can run from the receiver to a tv? im in haiti and i wanted to allow my neighbor down the street access to soccer games.
thanks
jose
It should work.
Try to as much as possible keep it a single line. Ive never ran a backfeed over 100
feet but like I said it should be fine. If I am wrong someone will correct me.
I will worn you If this is Dishnetwork or Directv you have It is illegal.
Let us know the outcome.
I'm thinking the output will be at channel 3 or 4. With RG6 having a loss of 3 db/100 feet at those channels a low cost amplifier will be able to overcome the 500 foot loss. Even with no amplifier you should be able to supply a slightly snowy picture after 500 feet of RG6 depending on the launch power of the receiver.
Oops 3db/hundred is the loss at channel 13, it's only 1.5 db/hundred at channel 3 meaning bareback without an amp should work fine at 500 feet hooked directly to his TV.
Tate Satellites said:
It depends on what type of cable you are using. I have run RG6 which is standard up to around 300 feet.
I'm thinking the stuff I have is RG6 plus I have some stuff my friend gaving me when he use to work for the cable company. It is under ground cable.
Thanks,
BigJohn2
Cannot get signal after moving... and no help from dishnetwork
Where did MSNBC go?
