A cable guy came to install two cable cards in my Tivo. He cheked the signal levels and said they are a bit high. So what he does is change some wiriing out and gives me this new cable amplifier. Unforunately I didn't stay in the basement where all the wiring is located the entire time he is down there. After spending 15 - 20 minutes in the basement, he comes up and asks me if the cable amplifier we had was store bought, I said it was. (Note he is caring a big bag attached to his belt the entire time he was here.)
He leaves and I check the signals on the cable boxes, not the Tivo and it states that in the 700mhz range it is: +11dmv. The 73mhz says 0dmv.
I'm not an expert, but does this seem to be an extreme range? Our basic analog channels are not clear, but I'm thinking that's because we are amping a week signal on the lower frequencies. (We have a three way splitter in our house, which is attached to a two way spitter on each port, so each port at the end is getting 15-5.5-3.5 = +6.)
The amp I did have was 15db forward and 10db reverse, he took that one and gave me one that is 15db forward and -1db reverse. My forward signal used to be 42dmv and now it's 54dmv, which seems a bit high.
I also think that there tilt compensator is too high in our neighborhood, since we have such a big difference from the low end to high end.
If anyone cares to repsond and let me know what they think about this, I'd be happy to hear from you.
