Iceberg said:What kind of quality do you get on those with your 3618?
VideoGrabber said:AMC8, I was never able to get that one, back when the Satcom-C bird was located there, but the power is a lot higher now with the replacement birds.
I could get a decent signal on the old Satcom 5 here in the Boilermaker State, but I can seem to raise anything on AMC 8. The footprint says it's good for all 50 states, but there's no analog to zero in on, when I scan I get a few signals but they never lock on (no channel) so I am sure that I am on it. The LyngSat chart shows some DVD, but I can't seem to raise them. If anybody is picking up any of the Alaskan stations on AMC 8, please let me know.
Sorry Iceberg, I kinda drifted from the subject.
Diamond Jim said:Sorry Iceberg, I kinda drifted from the subject.
Yes, it has been so long since I ran that...my lna had the same going to the blockdowncoverter... Here they are, on top the Amplica 120degree lna, middle the Sat tec receiver and botton the downconverter...VideoGrabber said:Iceberg,
> Drake 2775 Low Noise Block Amplifier <
Sounds like an old-fashioned LNBA. Should have some very thick coax running 4 GHz to a block downconverter to the 950-1450 range, then standard RG6 running out of that.
- Tim
what options are there besides H & V?VideoGrabber said:Iceberg,
> The only other thing on this setup is 3 wires (red, white, black) coming off the bottom of a box that say "3 wires pulse" <
That's the servo-motor, that drives the polarotor, controlling the angle (polarity) of the probe. They can set it to H/V or anywhere in between, in small increments.
that was kind of a stupid question> how much of an angle is the signal reflected off of to hit the LNB? <
None. I.e., the satellite will be perpendicular to the face of the dish.
I was eyeballing it by using my DirecPC dish which is at 38. Now that I understand the offset, it should clear. But how much of the dish has to clear the roof? If I set it on my deck, about the bottom 1/4 will be blocked by the roof...it sounds like I'm screwed.> The LNB at about a 40 degree angle will clear the roof. The true south birds for me (G11, T6, G3) are around 39....I wonder how low of an elevation I can get and still not hit the roof <
If this is accurate, then you're hosed, unless you raise the dish, or lower your roof.You MUST have a clear view of the satellites, even if it's only a 1-2 degree clearance. 1-2 degrees the other way and you're SOL. The entire arc will be below your "horizon". If you were just "eye-balling" it though, I wouldn't be pessimistic until you make an actual measurement. 39 degrees is a lot higher than it might seem, and unless you have tall objects very close to the dish, you might be surprised what you can clear.
The cable that came with it is very thick and heavy and also for the motor.. Looks like it has cable . It was about 100 feet and had some good weight to it> Drake 2775 Low Noise Block Amplifier <
That was my "new box" the older one was in a grey box with no labels... still have downconverters one 120 lna and 2 receivers...and yes they drifted, I frequently opened them up and adjusted the "pots" inside with a little screwdriver...Only thing was I cut up the feedhorn to try to hook a dbs lnb too with no successOregonboy1971 said:WOW, dfergie, I havent seen one of those ancient things since I had my old BUD in the early 80's. Those old 70MHz single conversion converters sure had a tendency to drift all over the place, didnt they. I finally got fed up and bought a Drake ESR-??? (their first block conversion satellite reciever) and a drake block converter with a male 'N' connector right on the case (the whole case threaded into the LNA) Boy, those were the days....![]()
