If from a Dish, I would agree. But to an outbuilding for a Joey?It's part of the install but most techs will try to get out of it trying to say another tech is coming or for you to volunteer to bury the cable yourself
I would think the opposite...that it is not part of a typical install and it would be an additional charge. From one of the OP's other posts, he said his "man cave" was his shop, which now appears to be an outbuilding requiring a cable bury...for a Joey. If I were a retailer, I sure would want it to be. But to the OP...if this is an outbuilding 40' away, what about a wireless Joey?
When Comcast buried a cable here many years ago, it wasn't more than 6" deep.What I would do in your position is to dig the 40' trench myself. It should be 18" deep and wide enough to drop the cable in. That way when the installer comes there is no question about extra billing.
When Dish buried my cable, as described in my post above, it was only buried a few inches deep. I can't really blame the installer because my soil was full of roots and very hard to dig. So far, I have not had any problem with the buried cable (and I live in Connecticut which has a fair amount of snow and ice - installed about 3 years ago).What I would do in your position is to dig the 40' trench myself. It should be 18" deep and wide enough to drop the cable in. That way when the installer comes there is no question about extra billing.
I bet you would go 18" for about a foot...then "going UP" the rest of the way.When I posted above that Dish only buried my cable a few inches deep, I did not mean that I recommend doing that. I was just describing how Dish did my install. I agree with Bobby. If I was burying the cable, I would try to go 18 inches deep.
That's why I suggested earlier that the OP dig his own trench in advance. The installer will take it from there....They likely won't do it at the initial installation either. Any digging, I thought, falls under "Call before digging" rules. They have to request the local utilities to come out and mark where any wiring, piping, etc is underground. Our house had a DirecTV dish, pole-mounted, and I wanted the Dish dish next to it. The installer wouldn't do it that day - he mounted the dish to a 2' x 2' piece of plywood and weighted it down with (2) cement blocks. About a week later, a different installer came back to dig the hole and set up the pole-mount.
What I would do is put a TV in the area facing the shop but inside your main house and have it connected. After the tech leaves, dig your trench, re-route and bury your own cable out to the shop, and relocate the Joey. If you're lucky, the node will be located outside and you can just run cable from it. Or, and some will have heartache over this, just use a coaxial coupler. I found a few websites that sell cabling and supplies that indicate some couplers that are "Dish approved".
