Bsc621-2
jagee
SatelliteGuys Guru
149
If my pansat receiver isn't set to the right Diseqc like for C band it says 1 and KU band it says 2,Will i not take in any transponders.I left it set at none.Is that why i might not be able to set up my dish and receiver
If you are using the BSC621-2 LNBF,you will need to assign Diseqc 1 for C band and Diseqc 2 for Ku Band on your receiver.
So i won't receive any type of signal until i do?Is that right.
pretty much. I tried one time without selecting a DIseqc port and got nothing. I knew it was aimed right as I just swapped LNB's from a working system
ill try that later on Ive been beating my head and not doing it the right way LOL
also make sure about the skew. I know on mine it was off by like 90 degrees for some reason
Galaxy 17 to Replace SBS 6?
UEN SciFi Friday Podcast
