Either a menu setting in the 410 or failure of the unit. Bottom line ...... Your 410 isn't putting out the correct voltage anymore to control a LNBF.
Iceberg said:Brian I checked all the settings when I was there and the 410 is a stripped down version of a 4DTV so I couldnt find any menu setting for that
SATire said:I understand that I need the 18V to get all of the channels .
So, you mentioned re-connecting so that the dsr gets it's feed from the geo now or are you thinking that has no value at this time?
SATire said:Just tried that, same problem. 240 not coming in, 241 is.
Do I need to change anything on the geo?
What I did was to lock W5 in the geosat settings so that when I menu to satellite pointing, my dish moves and the signal comes into the dsr410.
Since there aren't any channels I can pick up on the w5 bird, I'm not even sure how I would use it to tune to one or the other polarity and sounds like too much work anyhow so guess I need to find a replacement.
