I received a brand new Titanium ASC1 today. Really was looking forward to getting this going, but it is virtually unusable with my linear actuator on my 10' BUD. Keeping in mind that I have a GBOX V3000 that works just fine with this setup, I literally replaced it with the ASC1. Here's what I did:
I hooked up M1/M2 to the red/white wires going to my actuator.
I hooked up S1/S2 to the brown/green wires going to my actuator.
When I turn on the ASC1 and press the East/West buttons, the linear actuator moves the dish just perfect.
However, if I then connect the 100' RG6 cable from the DMX741 LNB on the dish to the LNB port on the back of the ASC1 and press the East/West buttons, I get a click and a rather long message on the LCD screen about limits, motor blocked, etc. The dish won't move -- instead I get this message over and over when hitting the East/West buttons.
If I turn off the ASC1, unscrew the RG6 from the LNB port, turn on the ASC1, and press the East/West buttons, the dish moves fine.
I have tried the following:
1. Connected a spare DMX741 LNB -- same results
2. Connected a Chapparel C-BAND LNB -- same results
3. Tried the second 100' RG6 cable in the bundle -- same results
4. Switched the wires on the S1/S2 terminals -- same results
No matter what I try, no matter what I do... if there is an LNB connected on the other side of the RG6, the ASC1 will not move east or west, but display this long message on the LCD.
I called Titanium support and talked to Brian. He suggested several things which I've since tried. I'm just out of ideas.
Has anyone seen this behavior before?
