Hi
After connecting it the first time, there was no video Composite or HDMI and the power LED stayed green.
I went to the internet to research the problem and an hour later when I went back I got video -did nothing to fix it-.
I spent the first night scanning and setting satellites, the next day after work the receiver was again with no video and it has been like that for a week while I got my USB Cable.
The A/V is properly seated until it clicks.
I verified the HDMI Cable and TV
I briefly connected an old receiver and all is fine (Ku on diseqc 4/4, C on diseqc 1/4, motor is fine)
Having or not having the USB thumb drive connected with firmware does nothing.
Ali has Chip Type=M3601s in the ini file
I have flashed
a) GSPMHD_20130626.abs
b) GSPMHD_0.16_12062012.abs & userdb_20121103.udf.
Most times the Serial Port fails connecting but when it connects it flashes fine.
I don't connect power supply when flashing, the LED is green as soon as I plug the cable.
It bothers me that it says "Download to sdram(Default Database)" when I download file abs.
Nothing...
Although randomly I get a blink of red
And sometimes when I change from A/V to HDMI on the TV the unit blinks red.
And today I saw the background image once for 2 seconds before disappearing.
Any suggestions?
How much time does it take to boot?
What is a normal LED color sequence? (the USB led is always off).
What is the proper setting for Ali Setting/Download abs Settings?
Both or default or user?
What is the proper setting for Ali Setting/DB Size?
Am I missing something before I request an RMA again?.
I read about some "looping" problem but that wouldn't happen with the newest firmware would it?
And if it is looping, would I see a different sequence of LED lights? or maybe a background screen? or it would be fixed by flashing the udf file right?
Does your remote blink on any key press or does it pulse?
I have flashed
Nothing...
Any suggestions?
