Blind Scanning Radio Mux?
DFC
7
Arkansas
I'm blind scanning the radio mux on AMC3 (4043/7140) with a Traxis DBS-3500. It does the job quite well, with one really tough exception. It only finds 16 of the audio PIDs on that mux, and I know for certain that there are a lot more than 16 audio channels on that mux.
Is this a limitation of the DBS-3500? Is it a common limitation of all the FTA boxes? Is there some trick I can use to scan for the other PIDs on the mux? Am I not holding my tongue right? :)
Anybody got an exhaustive list of the audio PIDS on that mux?
Thanks!
D.
DFC,
Are you sure you are on AMC 3? I have made numerous scans on 3 with no results. Sometimes I have G28 bleed over on to AMC 3, could this be possible. If you are sure you are on AMC 3, what polarity did you use?
DFC,
Yes, it's AMC-3. 4043 H, Symbol Rate 7140.
D.
FOUND IT!
I only pick up one religous channel on the Traxis. The Quali scanned 11, but they show no signal when I try to pull them up.
On the Traxis, it will find only one "radio channel." Go to the Audio menu and there are 16 different audio PIDs. Like I said, there are a lot more than that on that mux.
D.
pid list
6950 MPEG-2 Audio for program 1
6912 MPEG-2 Audio for program 1
290 MPEG-2 Audio for program 1
280 MPEG-2 Audio for program 1
3719 MPEG-2 Audio for program 1
7249 MPEG-2 Audio for program 1
1000 MPEG-2 Audio for program 1
8000 MPEG-2 Audio for program 1
1276 MPEG-2 Audio for program 1
1746 MPEG-2 Audio for program 1
4093 MPEG-2 Audio for program 1
2592 MPEG-2 Audio for program 1
5587 MPEG-2 Audio for program 1
5069 MPEG-2 Audio for program 1
1286 MPEG-2 Audio for program 1
2703 MPEG-2 Audio for program 1
2593 MPEG-2 Audio for program 1
4737 MPEG-2 Audio for program 1
750 MPEG-2 Audio for program 1
700 MPEG-2 Audio for program 1
5029 MPEG-2 Audio for program 1
261 MPEG-2 Audio for program 1
102 MPEG-2 Audio for program 1
6346 MPEG-2 Audio for program 1
8076 MPEG-2 Audio for program 1
4972 MPEG-2 Audio for program 1
5634 MPEG-2 Audio for program 1
****EDIT****
some of these may be dead air. Either way, they are all of the audio pids that show up on the mux
These are old names from the list I made several years ago but I crossed them to the current PID list the best I could. One notable exception is the Focus On The Family channels that are no longer here.
0102 Salem Radio Network Channel 6
0261 USA Radio Network Channel 1
0280 VCY America Channel 1
0290 VCY America Channel 2
0700 Ave Maria Radio
0750 Christian Broadcasting Channel 2
1000 Calvary Satellite Network International 2
1276 Moody Broadcast Network Channel 1
1286 Calvary Satellite Network International 1
1746 Moody Broadcast Network Channel 2 (WMBI Chicago)
2592 Salem Radio Network Channel 4
2593 Salem Radio Network Channel 5
2703 USA Radio Network Channel 3
3719 Salem Music Network Format B (The Word in Praise)
4093 Salem Radio Network News
4737 Salem Radio Network Channel 1
4972 Salem Radio Network Channel 2
5029 Salem Radio Network Channel 3
5069 Family Life Radio Network
5587 Salem Music Network Format C (Solid Gospel)
5634 USA Radio Network Channel 2
6346 USA Radio Network Channel 4
6912 Skylight Satellite Network
6950 Relevant Radio
7249 Salem Music Network Format A (Today’s Christian Music)
8000 Christian Broadcasting Channel 1
8076 Skylight Satellite Network 2
I'm curious what he used too. I made a similar list with TSREADER, but the channels were in a different order. There is no SDT in that mux, so the channel names aren't there, but I noticed that in the "Language" slot, there is a 3 digit abbreviation, which seems to correspond to the channel names posted above, at least for 3 or 4 that I checked.
A TSREADER generated (edited with Excel) list is:
AMC MPEG-2 Audio PID 700: Bitrate 96 Kbps Sample Rate 48 KHz
CB1 MPEG-2 Audio PID 800: Bitrate 192 Kbps Sample Rate 48 KHz
CB2 MPEG-2 Audio PID 750: Bitrate 96 Kbps Sample Rate 48 KHz
CS1 MPEG-2 Audio PID 128: Bitrate 96 Kbps Sample Rate 32 KHz
CS2 MPEG-2 Audio PID 100: Bitrate 192 Kbps Sample Rate 48 KHz
IU1 MPEG-2 Audio PID 261: Bitrate 96 Kbps Sample Rate 48 KHz
IU2 MPEG-2 Audio PID 563: Bitrate 96 Kbps Sample Rate 48 KHz
IU3 MPEG-2 Audio PID 270: Bitrate 96 Kbps Sample Rate 48 KHz
IU4 MPEG-2 Audio PID 634: Bitrate 96 Kbps Sample Rate 48 KHz
LF1 MPEG-2 Audio PID 506: Bitrate 192 Kbps Sample Rate 48 KHz
MB1 MPEG-2 Audio PID 127: Bitrate 192 Kbps Sample Rate 48 KHz
MB2 MPEG-2 Audio PID 174: Bitrate 192 Kbps Sample Rate 48 KHz
RR1 MPEG-2 Audio PID 695: Bitrate 192 Kbps Sample Rate 48 KHz
SK2 MPEG-2 Audio PID 807: Bitrate 96 Kbps Sample Rate 48 KHz
SKY MPEG-2 Audio PID 691: Bitrate 192 Kbps Sample Rate 48 KHz
SMA MPEG-2 Audio PID 724: Bitrate 192 Kbps Sample Rate 48 KHz
SMB MPEG-2 Audio PID 371: Bitrate 192 Kbps Sample Rate 48 KHz
SMC MPEG-2 Audio PID 558: Bitrate 192 Kbps Sample Rate 48 KHz
SNN MPEG-2 Audio PID 409: Bitrate 192 Kbps Sample Rate 48 KHz
SR1 MPEG-2 Audio PID 473: Bitrate 96 Kbps Sample Rate 48 KHz
SR2 MPEG-2 Audio PID 497: Bitrate 96 Kbps Sample Rate 48 KHz
SR3 MPEG-2 Audio PID 502: Bitrate 96 Kbps Sample Rate 48 KHz
SR4 MPEG-2 Audio PID 259: Bitrate 192 Kbps Sample Rate 48 KHz
SR5 MPEG-2 Audio PID 259: Bitrate 96 Kbps Sample Rate 48 KHz
SR6 MPEG-2 Audio PID 102: Bitrate 96 Kbps Sample Rate 48 KHz
VC1 MPEG-2 Audio PID 280: Bitrate 192 Kbps Sample Rate 48 KHz
VC2 MPEG-2 Audio PID 290: Bitrate 192 Kbps Sample Rate 48 KHz
Note above isn't the order from TSREADER, but sorted alphabetically.
Serious Help Needed.
Dynamic Remote Control
