What is a TRUE BLIND scan?
The reason I am asking is that ever since I got my box and sat I have been trying to get white springs,pbs and other channels to come up but I could not. I would get half of the stuf on 123 not the other. Well last night I figured out how to manually add all the info needed into the viewsat. And bam like magic white springs appeared, and many more soon followed. When I was first going to get into this I picked up a pansat 2300 from ebay for $20. Then after I got it I was told to trash it because it could not do a blind scan and I NEEDED the best blind scan reciver on the market for FTA. Hence bought the viewsat.
Now it is my opinion that a viewsat DOES NOT do a true blind scan, because if you do not have the TP and the S/R and FEC needed it will NOT pick up that channel. I have verified this. So once you have the correct sat info file that has been fixed you can then do a blind scan and find your channels. This is nothing more than my 20 dollar pansat will do. Last night I made a copy of the sat file and loaded it on to the pansat and did a channel scan and what do you know, it worked!!!!
I have been under the impression that you did not need to know the tp's and such with a true blind scan box, all I can say is with a viewsat you do, it nothing better than a $20 pansat. By the way I am running the newest firmware(v0107) and the newest sat file.
Can someone explain this? This one little thing has stumped me and I am sure that there are alot of others out there who are having the same problems that I did.
