I have the receiver part in my bed room the transmitter is in the living room. My tv antenna in my room lost my local channels when it's on. I unplugged the receiver unit my channels came back. Any idea how to fix this?
Sounds like the transmitter is introducing interference into your antenna which is degrading your OTA signal. The Blackweb has a listed range of 50 meters (164 feet). Average for these devices seems to be around 100 feet or less so it has a pretty strong signal. I would suggest moving the transmitter as far away from your antenna as possible to see if that helps. You could also try shielding the side of the transmitter that 'faces' the antenna. Let us know how it goes. Good luck!I have the receiver part in my bed room the transmitter is in the living room. My tv antenna in my room lost my local channels when it's on. I unplugged the receiver unit my channels came back. Any idea how to fix this?
Given that powering the receiver is what causes the interference, it doesn't sound like the transmitter is the problem at all.Sounds like the transmitter is introducing interference into your antenna which is degrading your OTA signal.
