So, we're on our third 922 in the course of less than a month, and we're thisclose to replacing it with a fourth. With the last two 922's, we've been having this bizarre occasional issue: if you press Guide, or Menu, or DVR, basically anything that makes the current LiveTV screen get small and go into the upper-left corner, most of the screen goes black. So, the little screen displaying what you're currently watching continues to show and to work properly, but all the rest of the screen -- where you should be seeing the guide, or your timers, or your menu options, whatever -- is totally blank. The only way we've solved this is to hold the reset button for 5+ seconds and wait for a restart. The problem is that things only get more bizarre once the reset has happened. The 922 then deletes about 5 of my series timers (it thankfully leaves my already-finished recordings alone) -- and it seems to choose the same 5 every time, no matter if I change their priority, or protect them, set them via remote access, etc. And here's the even weirder thing: even after changing to our most recent 922 (so this is a totally different DVR now), we have the same exact problem, and it deletes the same exact timers.
Any ideas?
Any ideas?
