I have a fixed postion 1.8 meter offset dish that I am using for c-band that is doing pretty well. It uses 1/2" allthread and jam nuts to position elevation and azimuth. The mount uses a 1 1/4" grade 8 bolt with lock washers and lock nut that actually holds the whole thing together.
This 1 1/4 " nut is adjusted loose enough that the dish will turn freely but not move in the up and down direction. From what i can tell the allthread bolts are about 18" long each and could easlily be replaced with actuators.
I thought some heavy duty teflon washers between the moving pieces of metal would provide some wear protection for the mount.
the big question is how to control both actuators. I could of course use a stand alone postioner such as a v-box or digi-box positioner but this only controls the azimuth since most all big dishes use a polar mount to track the clarke's belt on a fixed arc. I do not know if there is any type of polar or Horizon to horizon mount for the Prodelin brand dish.
I wondered if there is a controller out there that could recieve pulses from both the azimuth and elevation motors.
Another option would be to build an adjustable "bent pipe" mount that would mimic the motek sg-2100. My dish is mounted on a 3.5" stainless steel pipe that is 4 feet in the ground with a 24" concrete base. The pipe is also filled to the top with concrete. a bent pipe mound aimed at true south with a declination adjustment made of some angle iron with pins, bushings, large 3/4" allthread, jam nuts, and some creative welding. I do own a welder and can weld fairly well.
Let me know what you guy think of either idea. With the two actuators scheme I could track inclined orbit sats also.
Thanks for your help and suggestions
