This is really a question. What exactaly is this NIMIQ1 and 3 bit? I know Expressvu has signals from 2 satellites 91 and 82 West. Is a different oreintation required for Nimiq1 and 3? Possibly it has eomething to do withtransponders. I was of the oponion that all transponders worked some had a stronger signal than others. Is it possible here in eastren Canada that some transponders will give 0 signal?
Unlike Star Choice, Bell is using a rag-tag fleet of satellites to deliver its programming. They have two at 82 degrees and two at 91 degrees. To recap the history, Nimiq 1 was their original 91-degree satellite. Nimiq 2 was added at 82 degrees.
Sometime ago, Nimiq 1 experienced trouble with the solar panels and/or electrical system. The result was that they had to reduce power on some of the transponders. Weak signal complaints began to come in, especially under adverse weather conditions. As an interim solution, Bell acquired an old DirecTV satellite and moved it into the 91-degree slot to share the programming load. Eight of the 32 transponders (3, 7, 9, 11, 17, 21, 23 and 25) were moved to it. They named it Nimiq 3. But its coverage is not good in the extreme western US and deep south.
This did not bother Bell because they have a strict policy prohibiting distribution of their signals into the US. Star Choice is more benevolent and even has a "home-away-from-home" package to allow their subscribers who vacation here to get programming.
Late last month, Nimiq 3 ran out of fuel. Bell moved in another old DirecTV satellite near the end of its life to take its place. Their hope appears that it will last another year or so until a permanent replacement is launched.
Bell must take pleasure in renaming its satellites. Quietly, Nimiq 3 was renamed Nimiq 4i. The replacement satellite is called Nimiq 4iR, according to a recent press release. For some reason that I'm unaware of, they didn't put the 8 above-mentioned transponders on it. Instead, on April 28, they pulled a swap. Transponders 3, 7, 9, 11, 17, 21, 23 and 25 moved over to Nimiq 1 and 4, 8, 10, 12, 18, 22, 24 and 26 were put on Nimiq 4iR. This has caused much consternation among US viewers in the weak or non-existent portion of Nimiq 4ir's footprint. Many popular channels went away.
As a result of all this madness (and probably more to come), there is now more talk than ever about viewers in the "Southern Provinces" abandoning Bell in favor of Star Choice.
