Channel Master has a 20 foot mast for $60 with decent shipping but the larger ones have high shipping costs. Your best hope is to find a deal on ebay or a used one off of craigslist. There are a lot of the old 36 foot radio shack telescoping masts out there so there is a good chance you could find one that is no longer needed. I have seen antenna towers used by ham radio operators for under a hundred dollars on craigslist but they can require some serious effort to install.
I looked at your TV fool in the other thread and my opinion is that you shouldn't dive into a large tower right away. The hills may shadow your home enough where even another 100 feet won't really help. Use the other mapping tool on TV fool, where it says "Start MAPS", and test different heights.
There are free plans online to build a coat hanger antenna that you could use to do some testing and see how accurate TV fool is for your situation. If you can find a spot on your property or roof that works well with this antenna then I would go to the next level with a larger antenna.
