Best damn OTA antenna array, period. At any price. Which one?
And LINK.
Wingard makes an 8200U that is cheaper than the 3671 Channel Master. The specs look pretty good on it. I put a signal amp on my 3671 (CM7777). I'm getting 30 channels at night and 20 during the day. Wingard also has a signal amp that is about 20 bucks cheaper with similar specs. I pointed my antenna at Savannah, GA and get Augusta, GA on the backside. That way I didn't need a rotor.
finco 400-a-s
I would second the nomination of the finco 400 as best deep fringe home brew for VHF high. Even toning down the gain a little to keep SWR below 2.7 ( 2.3 max actual in last model) gives 11.5 -13.5 dBi net gain. And some 400s models hit 15 dBi at one optimized channel (but SWR climbs above 2.7 at more than 1 channel away from the channel optimized for... usually) The 400-A included notches to give UHF reception as well. Models show UHF performance is less than spectacular even though it hits a max of 14 dBi raw gain at channel 32-33. I don't know what gave such good results (175 miles to Lubbock TX) but the antenna models out at a net gain of 11 dBi at channel 28. So I suspect it was something besides just the antenna. I investigated this antenna mostly because I saw reviews that compared it favorably to a CM 4251 but sadly it doesn't. Also note this is a large antenna at ~ 8.5 x 7.5 feet.
