i'm new to the hd game and installed the h20-600 tuner a couple weeks ago. however, i ran into a problem:
- installed the BBC and set up the box...worked fine.
- turned off the tuner and turned it back on and it just sits there with the 771 code......searching for satellite.
- removed the BBC and the tuner works fine.
i thought this was a BBC problem so the installer sent me a new BBC. i installed it and the tuner is still unable to acquire data from the satellite with the BBC attached. again, the tuner is able to acquire data from the satellite with the BBC disconnected.
i purchased another tuner and successfully set it up with the BBC connected tonight. however, when i turned the tuner off and back on, the tuner was unable to acquire info from the satellite. i reset the tuner multiple times with the BBC connected to no avail. however and once again......the tuner works fine without the BBC connected.
i need to figure out what is going on so that i can view the new hd channels.
any thoughts? i'm going crazy here. thanks!!
