Mine has 0200, bought it from the freon site, seems to work just fine on the FW that came with it. So who cares. By now the cloners are aware of the so called "Good List" and can clone the good numbers into their boxes.
I"m still running the original firmware because the S9 works perfectly.
Remember, the clone ID is only for determining if the box is manufactured and authorized by Opensat. This is only important if you are using the official firmware released by Opensat.
The Opensat firmware now incorporates a clone kill to disable non-authorized STBs from using their firmware. This is Intellectual Property Protection 101.
If you are using firmware developed by a 3rd party, you should have no concern as long as you know what you have and what you are loading.
All I remember was the 1st few software versions had the switch/motor issue, wouldnt play AC-3 through the TV or RCA cables (you needed a converter) and the blind scan missed most everything under 6000 symbol rate
Mine is 0107. It works fine. I'm using a HDMI output to a 1080 HD TV. I changed software once way back when I got it to update the USA satellites.
you cant be running the original. I had one of the original S9's (Sathawk version) and the software was a big steaming pile of monkey crap...hel the 1st 5 or 6 versions were that
This may have been said, and perhaps I am missing something, but clone killing open source software as I assumed is in the Openbox just seems against the whole spirit of the open source movement.
Someone touched lightly on the "power off/on" issue. Is the symptom of powering off "not" powering down the video and sound (but front panel goes out) and not able to turn it back on without reboot a clone issue or a software issue? (Openbox 10)
I believe that means you have older FW that does not report the codes.
Mine listed as 0201 and turned out to be 9D1A after upgrading to newer FW.
OK so I went looking this morning to see what I could find out about the clone issue and my CCID of 0200 and here is something I found.
So I guess that my CCID of 0200 "may" not be a clone after all since that guy had one with 0201 and it changed after a firmware upgrade.
I think that the Skybox firmware is safe as far as the "brick" issue is concerned and I plan to upgrade mine to the latest version to fix the green tint and blind scan issues as soon as I find a backup copy of the version I'm running now. If it turns to stone I'll let you know.
