Note I want WB/UPN so waiting for the HDdvr doesn't help me right now.
local installer ($60 per hour) that I hired to put the DB8 that I previously bought on the chimney won't be back in the office until Monday so I wanted my options before then. I had it in the attic but couldn't get in fox (uhf 42) because it was 2 degrees off. I figured if I got 75-90 in the attic on the other nets, (except 54), that on the chimney would be a good compromise to get in fox because in theory the signal is stronger outside right?
Well after much fiddling, we got it to where ch 42/54/64/67 were all pretty solid 60-70. Thing is, even when he was fiddling outside, i never got 64/67 to as good a signal as I had in the attic. I guess this was more of a big deal than I thought at the time. Does it sound reasonable that because the chimney was actually 6-8 ft away from the site in my attic, that it may be the reason I never got in a good signal outside? I'm assuming the antenna is perfectly plumb but of course I have no way of telling. He did seem to take great care when he did the chimney mount.
So overnight we had a very bad thunder storm. however this morning all the channels were the same as yesterday. Then this afternoon the winds and rains kicked up and the channels were all unwatchable during the storm (going from zero up to 70 wildly). Even now that it's calmed down, i can't get back in ch 67 but the others are relatively ok. I'm assuming this means the antenna moved. I didn't think up high on a 10 ft pole was very stable but he assured me it was rock solid. Obviously this isn't true.
So i have to think of my options and it's frustrating
1. tell him the antenna moved and make them somehow shore it up. I'd assume they would have to do this free/reduced cost since it obviously moved. However the problem I have this this option is even at the time of install, i only got low 70s for a high signal when inside i was getting 80s. So this may be foolish to try and solidify an antenna in this relatively poor position.
2. maybe lower the antenna on the 10ft pole down a few feet to make it more stable? Or is this pointless given my 'weak' signals of 60-70?
3. I'm assuming you can do a tripod mount on the peak of any roof. (didn't ask him but i'd assume they can do that). I could have him stand near the spot where I had the good signals inside and try to find a good signal and I'd assume they should be the same/stronger on the roof at that point. Then we can determine how ch 42 will come in at that point. I'd assume they would do this as they are the pros and i dont see how else you could tell a good signal. Also if they can't get in all 6 networks, I may as well put the antenna back inside away from the elements.
4. try to lower the antenna for more stability and just aim for channel 42 then put another antenna back in the attic and get another antenna (though I know it's a 2 week wait for a jointenna unless I can do something like a reverse splitter? Of course then there's the cost for another antenna plus 30 for the jointenna. And now i'm really paranoid about outside mounts not being stable.
5. ask them what antenna they have for my area (I know the like wineguard) and ask him to do a test of it on the chimney mount.
I already spent 200 on friday. I dont know how much more I want to put into this. I definitely have to have him back here, even if just to take the antenna down, as I dont climb on roofs. My gut says have him use a tripod and at least try to move the antenna to a point where the signal is at least as strong as inside and get the antenna as low to the roof as possible to minimize wind problems. I guess the 6 ft to the one side made a big difference.
