Hi this is my first post. I have tried looking for this information with no luck. I have a ViP222k that I have setup to backfeed. The second tv is very fuzzy. I have changed the channel that it backfeeds on with mixed results. I have changed the triplexer and the cables. I don't have a diplexer to swap out. What am I missing; what can I check?
Thank you,
?Zach
You have to have a diplexer somewhere inyour system for a tv2 to operate with only 1 cable going to the reciever with a triplexer installed.
Chances are you have a corrode connector, damaged cable, or some other 'break' inthe continuity of the line.
But you must be sure both your tv2 and your recievers tv2 output are on the same channel.
At the reciever useing your remote press in this order on the remote:
Menu
6
5
This will take touting the modulator setup screen.
Proceed to set the TV 2 option to either air mode, or cable mode.
Make note of what channel the tv2 port says it will be on. Usually either 60 in air mode or 73 in cable mode.
After setting your desired out put. Proceed to the TV tat is your TV 2 and put that TV on the channel to match your recievers tv2 output channel.
If you set the reciever to out put on cable mode 73 and your TV at the TV 2 location does not go passed channel 69 your TV is in air mode. The easiest way to change modes is from the reciever. Go back to the reciever and go back to the modulation screen and put the tv2 output to air mode. Then return to tv2 and set it to 60.
If it is still fuzzy you have a cabling or connector issue. Or if these instructions don't make sense please contact dish and have a te h visit to resolve your issue.
If you want to test to see if your reciever is at fault, remove the cable on the reciever that connects to the TV distribution port and attatched a short piece of cable from the reciever to your TV at the reciever location and set your TV to the correct channel your reciever is outputting (air mode 60/cable mode 73).
If it comes up clear your reciever is still functional. If its fuzzy than you have no choice but to get a new reciever installed.
Good luck.
