What should you do in the event that your firmware fouls up the operation of your AZBox?
The following is the list of the first stage procedures that should be attempted to recover the AZBox operation. Print this out and use it as a check-off sheet as you go along. If any one specific step blocks you, mark that as your stopping point as that can provide a clue as to what other avenues may be necessary.
1] Power the system down normally, if possible, and remove the HDD (internal or external).
2] Disconnect the LNB IN cable. Leave the other video and audio cables connected.
3] Obtain a USB flash memory stick drive and ensure that it is formatted in FAT32 style.
4] Download a known stable (official factory) firmware image file such as 0.9.5020.
5] Copy this image file to the USB flash drive and rename it simply "patch" or "patch.bin".
NOTE: You may copy the image file to the flash drive and rename it "patch" and then copy it again and rename it "patch.bin". One file will be accepted and the other will simply be ignored.
6] With the AZBox powered down, insert the USB flash drive in one of the two USB ports.
NOTE: If the USB flash drive is not detected upon bootup, try the other port.
7] Power the AZBox back up and hope that the UPGRADE menu appears. The menu should have the following options:
1. USB
2. NETWORK
3. OTA
4. FORMAT APPLICATION AREA
5. BOOT WITHOUT UPDATE
8] Select USB, press OK and follow the prompts to load the upgrade.
9] UPGRADE menu screen should reappear when complete. Then select FORMAT APP AREA, press OK.
10] UPGRADE menu screen should reappear when complete. Now select BOOT W/O UPDATE, press OK.
11] If the AZBox reboots fully, but you cannot see a video on your TV:
Press the RESOLUTION button on the remote and watch the front panel display on the AZBox. It should show COMPOSITE first. Press the ?, ?buttons to select the proper video output format from the list of (COMPOSITE / COMPONENT / SCART / HDMI). Click OK and then select from the next set of options (PAL / NTSC). Click OK when the appropriate option is displayed. Now select from the resolution options (480i / 480p / 720p / 1080i / 1080p) and press OK.
12] If and when the AZBox fully reboots and you have your video back, go to the:
SETTINGS MENU ? DATA RESET ? FACTORY SETTING
NOTE: You may need to enter password 0000 for access permission.
13] Execute the FACTORY SETTING by highlighting that option and pressing OK.
14] You may need to repeat the performance of step 11 when this has finished.
15] Your AZBox should now be restored to factory conditions with the default factory satellite and channel list installed.
16] Power down and reconnect your LNB IN cable (leave the HDD out for now).
17] If you had backed up your personal satellite and channel list previously (before the fault occurred) you may download it back to the AZBox using the ACC 1.1 program utility. If you didn't save a backup file of your lists, you will have to reprogram the sats and scan for channels.
18] If all goes well, you may reinstall the HDD (you should not be required to do any setup for that). Simply start from the fuly powered down state, install the HDD and power on and let it reboot.
RADAR
