Azbox Enigma2 RTi core RC3 released
ultimately the benefit is that enigma is opensource.a couple things i like about enigma: in the antenna setup you set up an lnb and then assign the lnb to a satellite. its more efficient than setting up diseqc/22khz for each satellite seperately. you can enter diseqc 1.2 positions numerically instead of having to scroll thru numbers. the ability to overclock in 5mhz steps. the channel editor is more mature and actually being developed. since the dreamboxes are in wide use in europe and enigma basically turns the azbox into a dreambox clone of sorts so there are more plugins / skins available. etc. etc. etc.
if you want me to test some recording tonight just let me know which feeds to try. i think the recording function was only added in the last 2 releases so it may or may not work at this time.
crackt out,.
Try these for recording:
Galaxy 28
3919 V 29857 9/10 DVB-S2/8PSK Pilot Off
3880 V 29860 9/10 DVB-S2/8PSK Pilot Off
Galaxy 19
4079 V 29856 9/10 DVB-S2/8PSK Pilot Off
4139 H 29857 9/10 DVB-S2/8PSK Pilot Off
4179 H 32359 3/4 DVB-S/QPSK
Galaxy 16
4119 H 29997 9/10 DVB-S2 / 8PSK (Pilot Off)
3739 V 29997 5/6 DVB-S2 / 8PSK Pilot Off
4139 V 29987 9/10 DVB-S2/8PSK (Pilot ON)
What your looking for is to see if there the recording is broken up.
Viewing the signal when recording gives you a clean picture it is the recording that is messed up .
Try Galaxy 28 first.
From what I've read the ability to record is limited with E2 RC3 as it was just added although I'm curious as to what crackt will find.
