Ok, we were able to replicate your system over here using a DMS International 8x1 DiSEqC switch along with a V-Box II and got this setup to work successfully.
However, we have discovered that the DiSEqC 1.1 switch type option is not generating the correct DiSEqC switching commands so you have to use the Advanced option instead along with the following antenna setup for your satellites:
LNB frequency: Standard 5150 (LNB type to use for this satellite)
DiSEqC input: off
Committed input: off
Uncommitted input: 8 (DiSEqC 1.1 switch port)
22 KHz tone: off
DiSEqC motor position: 18 (Position number on your G-Box for this satellite)
Use USALS: Off
Once saved, try to scan a known active transponder using Manual transponder scan and it should work. If you still have no signal, please do a receiver shutdown and unplug the AC power cord for about 15 seconds in order to reset the tuner and try to do a manual transponder scan again.
Hopefully this gets you up and running. We have created a bug report in regards to the DiSEqC 1.1 switch type not working in order to resolve it in a future firmware update.
Best regards,
PwrSurge
AzBox Canada
DiSEqC input: off
22 KHz tone: off
Use USALS: Off
Best regards,
PwrSurge
AzBox Canada
