Setting up a AZ miniMe, I was going thru this configuration after my first power up. Accidentally exited out and now it is gone. Can this be re-started? I tried going thru the menu's manually but the setup doesn't work.
Version 1.7 is the newest firmware. Hit menu, channels,tuners,setup tuner, setup tuner 1. This should get you to diseqc commands as well as sat activation and antennae setup.
Catamount
Yup did that sequence already.
If I re-connect my Raptor to the same coax, the dish, switch, and motor work fine.
Must be something I skipping in the AZ setup.
Sorry but the link you posted doesn't work for me.
Meantime my setup is AZ miniMe> Gbox positioner> 1.1 switch port 8> LNB.
I checked those settings best I could, but some of my screens are different than yours. I made a video showing me going thru several menus, it's a little long but maybe you can spot something in it.
http://youtu.be/JaAizms6PmE
|=========== LNB 1 & 2 === (=
miniMe ---> GBox ---> 8 x 1 DiSEqC switch |=========== LNB 3 & 4 === (=
|=========== LNB 5 & 6 === (=
|=========== LNB 7 & [B]8[/B] [B]----- [/B](-
Did you find out what was wrong with the box or still not working?
