You're lucky - no 100+ F outside and poor A/C in July there. Anyway 100F is good temp for the HDD - just slight fever by human scale.
I'm new to Dish and have already fried one DVR, most likely due to temperature (was running at 104/123/140). I'm putting my A/V equipment in a cabinet under the TV. The cabinet is enclosed. Right now, I do not have air coming into or out of the cabinet. After learning of the temperature issue, I've used two of the USB Thermaltake fans. I have these blowing into the front right side of a 722k and blowing out of the left back side.
I have a few questions:
1. How often does the temperature counter update? Is there anything I need to do to update it?
2. What average temperature should I aim to be under?
3. What is the best place to put fans around the DVR?
4. The Targus notebook pad fan is on sale at buy dot com. Has this item worked well for cooling the DVR?
If you have a chance and patience you need to read this whole thread. All your questions will be answered.
4. The Targus notebook pad fan is on sale at buy dot com. Has this item worked well for cooling the DVR?[/QU
NOTE]
I will try to help you some from what I can remember, but my wife says I have sometimers disease so not sure if I am right. I have the time but not the patience to read long threads.
1. Only the Dish Gods know how often the temperature counter updates and they aren't telling. But, I bet Smith, P. knows!! There is nothing you can do that I know of to update it. From my experience it seems to update every two to three days or when it feels like it.
2. I would try to get the temp below 110. When I first got my DVRs one of them was hitting in the 120s and it was acting goofy. Installed dual fans, got the temp down and it has performed flawless ever since. See my spread sheet in post #811.
3. Install the fans at the air vents on the left side as you face the DVR to pull the air thru. Two fans work best. Check out the pics in this thread.
4. I tried out a notebook cool fan and it did very little to lower the temps.
Hope this info helps you out some.
Supermatt,
I've have read the entire thread and generally have tried everything. The notebook coolers (I have 2 Targus and will sell them to you if you want) work but they are loud enough to be heard in a normal room. Steve P's fix is the best but it requires extensive modifications to your DVR.
The side USB powered fan didn't work at all for me... Don't know why.
What did work and is so silent that you have to put your ear within 6 inches to hear them going is the following from Coolerguys. They have 2 120mm fans and like the Targus you just sit the DVR on top of it. There are bottom slots that fans will blow cold air into and it works great.
In fact, it works so well, I bought another one for my stereo rack. Wedged it between the top of the amplifier (pulling hot air out the top vents) and sat my Apple TV (that puppy gets hot!) on top of one of the fans after I put some small stick on feet on the ATV.
See below:
Comcool Cooling Stand Kit with Dual 120mm Fans
I have had the Thermaltake fan on my box for a week now and the new numbers areMy 722 is
High 134
Low 107
avg 123
The average was 125, but i put a small fan sucking out the hot air from the left side and it dropped to 123 in 36 hours. I guess i need to see about an actual computer fan.
It is in the wide open, no entertainment center or anything blocking it.??
That looks like a neat setup. I think I will try it out. What did you get your DVR average temp down too?
Thanks guys, good stuff.
Another note: I'm using a usb hub with success to power the fans. (This has probably been mentioned before, but figured I'd share in case it wasn't.)
Before dropping $60 on that comcool fan, I think I'd attack the circulation in my cabinet. I'm thinking a fan like this:
120VAC 4" Fan - RadioShack.com
hooked up to an attic thermostat:
Thermostat,Attic Fan - Line Voltage Thermostats - Controls - HVACR : Grainger Industrial Supply
so it doesn't have to run all the time. Only downside is I'll have to cut a big hole in the top of the cabinet behind the tv and hope the fan isn't too loud.
Done. Added picture.Would be more informative to post a picture of your setup.
