Attached is 320kbps MP3 file with an example of the problem.There's only one feed as far as I know, at least on DirecTV. I'm on the west coast and as discussed above, it's bad here.
Are you just using your TV speakers?Attached is 320kbps MP3 file with an example of the problem.
someone at AT&T needs to fix this problem and it's clear they don't care about AXS TV, image this issue was happening with TNT, ESPN or USA, then AT&T would have it fixed ASAP.
Why ? (your probably right though).just check again, Audio issue is still continuing for AXS TV and that confirms AT&T don't give a F*** about this channel.
Sent from my SM-A205U using Tapatalk
Doesn't DTV have a network headend where they can monitor every channel coming in.Why ? (your probably right though).
ATT more than likely has never seen or heard of this site.
You posted about it here and expect them to get right on it ?
It takes them a year to replace a few spans of cable and you want this fixed Now ?
Fwiw, I have that channel on now and am having no issues.
the audio only sounds fine during the local ads that come from DirecTV's uplink center. the rest of the audio is crap, from the AXS TV national ads to the programming.Why ? (your probably right though).
I'd imagine they have meters on everything.According to someone who used to work there, the monitoring is automated now. Even if they had people monitoring it, they can't have the audio for 2000 channels on all at once...
Unless you can reach someone at the top it won't do any good.Has anyone sent a email to the network or gone on Facebook, Twitter etc. to complain about it?
OK at least you tried.I tweeted at them — they responded, but wanted to start troubleshooting my equipment. I wasn't about to go down that rabbit hole, so I replied that all they need to do is tune to 340 and LISTEN.
OK at least you tried.![]()
