Immediately after installation in 12/09, I had recurring audio drops on my new 722k Dish setup. The fault is triggered when recording using one tuner and watching live tv using another tuner. At that point, if you pause or rewind the live feed, when playback resumes, the audio drops out every few seconds from that point forward. If you then record that program, the drops are also present upon playback. Resets fix the issue for a short time, but when you replicate the fault inducing conditions, the problem recurs.
Connection is HDMI from the 722k to the Pioneer VSX 918V amplifier. There is an OTA module installed but the fault appears to be completely independent of it. Box is in single mode.
Dish sent a replacement 722k. Same problem under the same conditions.
In addition to the 722k to Pioneer amplifier HDMI link, I've also got the audio and video feeds from this 722k sent to a VCR via RCA cables, and from the VCR to the Pioneer amp using RCA cables.
I just replicated the conditions necessary to cause the audio fault, and had the audio drop clearly (and annoyingly) present while listening through the primary HDMI link. I then changed the Pioneer input so that I was listening to the same program via the RCA feed, changing nothing else. Via RCA, there were no audio drops. You can switch back and forth at the Pioneer amp to listen to the HDMI feed (problems) and then the RCA feed (no problems).
Fascinating. Irritating too.
So I took the audio signal from the 722k to the Pioneer amp via an optical cable. Same program still playing with audio drops. Only audible on the HDMI feed. Not via RCA or optical links.
So I moved all of the equipment and rewired as this problem dictated. The video signal now goes direct to the TV from the 722K via HDMI, and the audio travels solo from the 722k to the amp via optical. That's fine, as far as it goes, but since my HDTV is several years old, and thus has only one HDMI input, I am now forced to take the BluRay player video signal to the TV directly, where I'm forced to use the component video jacks, since the only HDMI input is now monopolized by the direct feed from the 722k. Not ideal.
I am reposting this information since it may help somebody else with their audio headaches. The new connection scheme resolved all issues. I am going to have a new AV Receiver in place in the next 30 days, will try again on the hoped-for connection sequence (via HDMI from Sat Receiver to AV Receiver, and via HDMI from AV Receiver to TV), and will repost with any information on that. Obviously there have been 722k software changes since the original problems occurred, so if they do not recur when I change over, it will leave unanswered whether the correction comes from the new software, the new AV Receiver, or some combination of the two.
