My AT9 Dish has been giving me some problems with the 110 LNB cable. It seems the little cable that connects into to the main 101 LNB has a bad connection. If I just rotate the connector wire a little, I get signal back. The 119 connection is fine. It seems if there is a high wind, or massive temp change, I loose signal from the 110.
Is there a way to tighten up the connector? It is very small.
