Titanium Satellite ASC1 going to sleep
  • Server Issues.
    We are very aware that there have been system issues the past few days. In troubleshooting the system, it has been determined that the issue is at our provider and is hardware related. As of 12:05 PM ET our provider has moved us to a new server.
    Things seem to be running better on this new server. However in trying to diagnose the issue (before finding out it was a hardware issue) we made some system changes which we need to undo. So if you find any issues or errors please let us know in the Operations Center Forum.
    Thank you for your patience! Sorry for the issue!
On the COM port not working, make sure you're using a null modem cable to connect to your computer, a standard serial cable won't work. At least, a serial cable doesn't work on mine. Mine is an old one, it could be different now with the newer ASC1's.
The ASC1's are more sensitive/not as tolerant to any problems in the system than vboxes, but the ASC1 is more complex also, more precise. I've thought mine was screwed up a few times because it was acting up but a vbox would still work and it ended up being motor/sensor wiring problems.
