i wondering if my ariza extreme is over heating?it loosing signal if i switch it of at the back and leave it for a while and switch it back on it works for a while .then the same thing happens ,also wondering if g10r is experiencing any problems?
It could also be the LNB drifting as it heats up.
Easy way is to replace the receiver if you have another.
That's not 100% sure-fire test,because a different receiver may be more frequency tolerant.
You could try entering your transponder frequency a little higher or lower, to see if that helps.
And yes , of course, it could just be the receiver.
