The ViP is a total machine(in a good way) let it breathe if it wants to breathe, while in the mean time its giving you amazing privelages. But to answer question use a mat of some sort.
Yes. The HDD high temp is 140 F, low temp 84 F, and ave temp 118 F. The unit sits on the bottom shelf of a coffee table. There is nothing on top or on either side of the receiver.Did you check the HDD temps by any chance?
Your high temp is higher than mine which is 138. You must have something different than the readings that I have seen You have a very large swing from the low to the high. I wonder if it is going from a very chilled to the high. My avg shift is only 18 (120) degree and low is 33 (105) less. You have a swing from 84 to 140 that is 56 degrees something sound out of the ordinary. The only time I have ever seen my low temp similar to yours was in the 1st few days that I had it.Yes. The HDD high temp is 140 F, low temp 84 F, and ave temp 118 F. The unit sits on the bottom shelf of a coffee table. There is nothing on top or on either side of the receiver.
If it is free standing, you could place a USB laptop cooler under the unit.
Smith, P:Fan start rotating at half speed when temperature of PCB ( IC U16 located between HDD power connector and sat tuner chip) reach 55°C. If you could put a thermocouple there and measure it, then I could tell you if the LM75 is bad or not.
