I only have one splitter as far as I can tell between the amp and the run from the pole to my house. Why don't you want to amp the signal for the modem?
GMFreak8 said:
digiblur said:Ouch!! 18dbmv on the forward! Most DOCSIS modems are rated from -15dbmv to +15dbmv with 0 being perfect. I'm suprised yours works.
Try to give us a lay out of your cable system in your house.
What the heck is a DC-9? I thought it was a plane?webbydude said:I wasn't quite sure on the levels of threshhold. Been too long since I've installed for TWC or Adelphia. And isn't that the whole point of using DC-9's instead of typical 2-way splitters; to pattern and bring the levels to a comfortable point for the cable modem??????
GMFreak8 said:What the heck is a DC-9? I thought it was a plane?
Edit: Diagram to come
digiblur said:DC-9?? Testing my brain or maybe my age, eh?
They were used back in the day before we had DOCSIS here. They were basically a splitter that one leg that was isolated and sent to the cable modem. The other leg was -9db (hence the name DC-9) and went to the rest of the house for the TV service. In our area they aren't used anymore....
Now the best setup is.... Line from the tap, to a 2 way, first leg goes to the cable modem, next leg goes to TV service. The TV service leg will have a 3 way splitter, 4 way splitters, or amp(s), etc. depending on the house. That way you only get a -3.5 db drop from the tap plus the loss of the drop. In most cases this works well.
webbydude said:Actually, you supposed to run the cable modem on the -9 dBm side. The cable modem doesn't really need a strong signal...just a clean signal. The other side of the splitter is supposed to not have any signal strength taken away. In a perfect world it decreases for the modem...doesn't decrease for the rest of the video outlets in the home.
GMFreak8 said:Ahh ok.
I tried drawing a diagram, but I could barely understand it myself.
I'll try to explain it in words.
The cable comes in from the pole to a grey box mounted outside my house, from there it splits using a three way splitter, one goes to my bedroom, one goes to the spare bedroom, and then the last one goes into the living room. The one coming into the living room has the amp first, then a two way splitter. From the two way splitter one feed goes to the cable modem, and the other goes to a four way splitter. From the four way splitter one feed goes to a HD DVR, one feed goes to a Standard digital cable box, one goes to a analog tv, and the last goes to another analog tv. That's the layout. Hopefully you can understand it.
GMFreak8 said:Time Warner really pisses me off. I actually have a card from a Time Warner technical supervisor that came out when I was having major problems. I wonder if I should just call his number directly and set something up. I mean, I'm not having major signal dropouts and the speed on the cable modem is decent, but there is some artifacts on the HD channels that I just can't seem to get rid of. Digiblur, did you do that setup or did Time Warner come out and set that up? Your signals are like night and day compared to mine. The analog stations are fairly fuzzy too, some so bad that it's worse than an OTA antenna. I guess I should get after them, I'll probably wait until the end of summer though, I'm fairly busy through August.
BTW, do you know how to get into the grey box on the outside of my house, so I can make sure what type of connections are in there? I can't seem to get it opened. Also, some of the wiring in this house is from the early 60s, that should probably be replaced too, right? I have a picture of the box on page 2 or 3.
TAP
2WAY
Cable Modem Amp
2WAY
3WAY 3WAY
digiblur said:Wow!! No wonder you have problems... 7 drops.... just like I have at my house. This is my setup:
The only thing you don't see is the 2 way off of one of the -3.5db legs that is behind the living room TV: One for the HDTV QAM tuner and one for the MyHD PCI QAM tuner card.
Notice the difference in cable signals??
Frequency 705000000 Hz Locked
Signal to Noise Ratio 40 dB
Power Level 1 dBmV
Channel ID 4
Frequency 25008000 Hz Ranged
Power Level 39 dBmV
webbydude said:Now that's a thing of beauty! Definately slide-show material for any installer...beginner or advanced. And yes, that's kind of what I was trying to describe to GMFreak; amp out your signal AFTER you split to your cable modem. At the same time, keep your modem on the 1st splitter.
cable-guy said:digiblur, what on earth is that setup? if i left a service call with something like that, i would lose my job. TWC policy is to homerun all lines to 1 splitter. the only exception to that rule is if it is literaly impossible to do such. cascading splitters could be the cause of all kinds of hsd problems. i would like some more detail of your setup, because if it gives you no problems, i am gonna set mine up like that.
digiblur said:
