Anybody use Coolsat 8100 HD ?
brentb636
4,278
6
5 miles N of Saugatuck, Mi
I've noticed some used CS8100 HD PVR boxes on ebay, at under $200 . Anyone care to volunteer how they like this box ? I like the CS8000 that I have, and adding a PVR capability would be sweet for HD channels. Suspect the used units are a result of Nagra 3 hitting the hacker world, and this could be a blessing .
Yeah, I have an 8100. Actually two of them. I bought the first one last spring, but it got zapped by lightning this summer. I liked the receiver so much that I bought a replacement, however the replacement "was" defective. I sent it back under warranty, but it came back with the same problem... would either lock up or reboot on it's own every 25 minutes.
Originally, the 8100's PVR didn't work. Basically, you can record, but not play back without stuttering, although you can take the recordings and convert them to .mpg files to play on computer or streamed to Roku or something. However in some recent firmware updates, they have apparently fixed the PVR function.
The recent firmware also seemed to have fixed the lockup/reboot problem that my new 8100 had, although I'm almost afraid to touch the thing for fear that it will come back. When the new 8100 gave me problems, I bought a Diamond 9000 to do PVR with, however the ebay seller wasn't honest about having put hacker software on it, and it was stuttering on any HD channels. It also recorded OK, and I could play back via computer or streaming. Interestingly, the Diamond started working again today too! So now I have 2 PVRs.
Anyway, sorry that I can't comment much on the 8100's PVR, because I've been afraid to attach the HD for fear of causing it to start rebooting or freezing again, but it recorded OK before. But even if you don't use the PVR, the USB allows you to update firmware via a USB thumb drive.
BTW, the 8100 I have is basically a 8000 with PVR. The motherboard is labeled as CS8000 . Anyway I really like the 8100, but mainly for the fact that it has a sensitive tuner that does DVB-S2, and it does mpeg4, etc, same as the 8000.
I'd been curious about the 8100, too.
I asked the difference between it and the 8000 a while back, and the only answer I got was "the 8100 adds PVR capability"
There are so many HD boxes with similar model numbers, and I wasn't sure if the 8100 did S2 out of the box or dropped any feature of the 8000.
I know it cannot blind scan S2, but what was the other shortcoming?
The Diamond won't take S2 parameters via the remote...?
What did the Coolsat not do?
Well, I know there's no blindscan at all, like the CS8000 . If it works as well as the CS8000, plus the PVR function, it should be just fine. Maybe somebody else has one AND uses the PVR .
I ordered one last week and it is due to deliver tomorrow. I finally decided I needed HD since I kept hitting HD feeds! Also the OTA tuner should be nice also.
I'll report back on my findings, assuming it is not DOA or something. :)
Wait, none at all for anything? That can't be!
If it is, that's probably why I never got excited about the 8000.
We could use a review, but even just some pro/con comments would be helpful. - :up
Someone should write a short table with the good/bad features of these units.
For the most part, they don't suit me, but I'm picky.
Others live with the shortcomings, finding the good outweighs the bad.
And that's fair. I won't argue so long as they're happy.
But to encourage newbies to get most of these boxes for their first unit, would be irresponsible.
Switch command capability: diseqc 1, 1.1, 1.2?
Motor control: USALS that works
Blind scan? how well does it find low SR signals, get confused on bad signals, speed of search?
Need tuner card for full capability?
PVR capability (I'd never have another receiver without, but that's just me)
S2 parameters - how do you get them into the box?
There are more categories, but these are just some of the basics.
"But to encourage newbies to get most of these boxes for their first unit, would be irresponsible.
For a first unit, I agree. MUST have blindscan ! For a $200 unit that does USALS and HD and DVB-S2, though, you can't be too picky. The CS8000 DOES work, and if the CS8100 works as well, and adds a PVR that works, for $200, then you've got a deal. Too bad the economy has gone to crap. Last year , I'd have had the money to burn on one.
one more
One thing I forgot:
If it receives digital OTA (ATSC), then is there any sort of poor-man's guide at all?
All the $50 DTV converter boxes can tell you the name of the show you are watching, something about it, and usually what's on next.
The good ones can tell you all that for several shows ahead.
My Channel Master 7000 * box certainly does a credible job (12 hours ahead if data is available).
* cheaper on sale and at other sites.
the 8000/8100 is a different menu setup than the 4/5/6000 and no there is not a blind scan on either the 8000 or the 8100
A bit more info.
Apparently, a very early firmware version of the 8100 had a working PVR, however since it requires FAT32 HDD format, it only recorded like 4GB, which isn't enough for most HD. Later firmware versions allowed it to record multiple 4GB files that could be played as one, however there was a serious bug in playback that resulted in either severe freezes or in my case caused a reboot. Ie it recorded fine, but couldn't play back. However the most recent firmware versions have apparently fixed that. The files are recorded as .TP0 files, which are transport streams that can be converted to .mpg via VideoReDo.
Re good/bad points of the 8100, in previous post I didn't mention this because it's probably the same for the 8000, however there are several annoying defficiencies.
One problem is that you can only define 31 satellites at a time. Ie if you want to scan a sat, that sat has to be on a list of 31 sats that are selected from a much larger list of satellites. I found that this wasn't nearly enough if you want to define both C and Ku satellites.
Another issue, which in related to the above, and to some extent helps with the above issue, is that saved channels are not relative to saved transponders. What I mean is that say you have a universal lnbf, and scan in 20 channels on a satellite, then switch to a standard lnbf. With most receivers, you just change the LO settings in the satellite/transponder setup and you can now use the previously saved channels. With the 8100, you can't do that, because the satellite/transponder data is stored as part of the channel data. If you now do a rescan of the satellite, you will get 20 new channels, and have 20 channels that work, and 20 channels that don't work, which you'll have to delete. The good thing about this, is that it helps to some extent with respect to the 31 satellite limit, because you can save channels that are independent of your list of satellites to some extent... just hope that you don't have to change parameters.
Related to the above, if you have a bunch of sats, transponders and channels saved, and want to update your firmware, or need to reset to factory conditions for some reason, and you try to save your channel data to restore later, you can save the channel data, and that data will include the channels, and a list of favorite 31 satellites, but all the sat/transponder parameters will be lost, so before you can scan in any new sats, you'll have to redo all the sat parameters, basically re-define your 31 sats, etc, etc. Basically it is impossible to restore the receiver to a previously saved state. You can restore the channels themselves, but it gets very mixed up when you try to select these channels from a list of satellites that now doesn't exist, etc, etc. I found that I had to just delete the restored memory and start over from scratch each time I've tried to restore satellites or changed firmware.
The above is probably the reason why there is no channel editor for this receiver. Ie it would be useless, unless you use the default satellites and sat parameters.
THere are some other problems, such as selecting audio streams, defining AC3 or MPEG4 on manually created channels, and I think I've forgotten a few other problems but the above are the major ones I think.
You'd think that after all the above, I would hate the receiver, however despite the pain it is to set up, once set up, it is a really convenient receiver to use. The OTA ATSC works great, and the channels are seemlessly integrated in with your satellite channels, making it one of the few receivers I've had that was user friendly enough for my wife to actually use.
I really like the 8100, and I'll probably give it the PVR another try soon, because my Diamond doesn't seem to work on the channels I want to record, whereas the Coolsat worked fine back when I did use the PVR. The 8100 has a very sensitive tuner, and locks transponders that my TT3200 doesn't lock.
The lack of blind scan is unfortunate, however I think I've only heard of one DVB-S2 receiver that did blind scan (can't remember which one that is), and there were other problems with that receiver. I think overall, the 8100 is the best DVB-S2 receiver out there at this point, at least out of the box, without adding modules, etc.
Thanks BJ,
It sounds like the 8100 is the 8000 with a PVR grafted on. I've seen all the problems that you have seen, when trying to find a system of channel backup and system backup. I, too , have found it easier to simply start over from scratch on the CS8000. If I can get a used 8100 for $200 or less, I'm going to do it.
I have the 8000 so I can confirm your points
yep...31 max which is fine if you go from 61.5 to 148 and just KU & DBS but if you want C-Band you have to mix & match
yep it wont remove the existing channels. So if you switch satellites and move say H2 from sat 4 to 5 you have to rescan
yeah I have issues where it thinks there is a AC-3 stream but there isnt so it logs the AC-3 stream....ABC on G16 C-Band is one example
I just recieved my CS8000 today, I have been googling about channel list for it. I came across a post in a eye patch forum that says the newest bin eliminates the 31 satellite problem. I might load it to see if it works for the sat limitation problem.Also it makes it so you can upload your list to the PC to modify it supposedly.I will have both Ku and C band hooked to mine so it sure would be nice to load the entire arc. I will let everybody know how it works over the weekend.
I've been using that firmware a couple days, Comptech, and so far I like it. They left out Amc16 Ku, though and took away the capability of adding and deleting satellites, so I've used BrasilSat at 84W, and then Motor Control to get AMC16 and saved the spot.
Big advantage for me , since I'm always "toying" and having to setup the box from scratch, is that with THIS firmware, you can actually upload the CS8000 to your pc, clear out the stb and reload it with your saved configuration. That wasn't possible before, unless you never changed the sat table from it's defaults.
I've posted to the coders to update the Factory file to include AMC21 and AMC16 in the new version and keep this full satlist format. Maybe a chance to get some support ?
Brent, I played with the latesr factory firmware last night and found it kinda "clunky". This morning I loaded the other and it is much better to me. The only thing I noticed wierd was that I am watching a big ten game on AMC15 and I am getting alot of pixelation with a signal of 88 and quality of 97 on my four foot Ku dish. Have you noticed anything like this with the new firmware?
"Clunky" I've noticed, but the Coolsat 8000 stuff is kinda clunky anyway. I haven't noticed any reception problems, pixelation, etc, and I'm only using a 90cm dish. Maybe the pixelation is uplink weather related. We're having intermittent showers right now in Western Mich. In fact, right now I'm getting LPBS from AMC21 very nicely, no pixelation, and THAT channel is frquently a problem for me.
On balance, so far, I haven't seen anything to take me back to the latest factory firmware. I'm hoping for a new factory release, similar to this hacker stuff, but with AMC16 and AMC21 added . Wouldn't bother me if they found a way to add blindscan, too, but I suspect they don't have the right chips onboard for THAT. :)
On G28 the race feed came in at 44 quality and played fine, so I think you are right about a problem with the uplink. Now that I have been using this reciever the Diamond is gonna take the back seat for awhile. This has a great tuner and easy to use.
It's certainly easier on the DVB-s2 stuff. Just key it in with the remote. I bought my CS8000 just for HD and DVB-S2 feeds, but now I use it as my primary box. It's not all bad , once you set it up, and with this latest firmware you can confidently (?) back up your channels and have a chance of restoring them later.
Hi
I'm curious re what has changed re to restoring channels with the newest firmware? I've completely given up hope of ever restoring channels on my 8100, mainly because of what is saved in the channel data files. Are you using the 1444a? I think that there is a 1447a version floating around too.
No, I'm actually using version 12001F ( a now out-dated hacker file) which is the first firmware that gets rid of the 31 sat limit. Now , all the sats in the box are configurable. ( Unfortunately, I know of at least 2 bird they don't have in the box, but that can be overcome ).
What I've done is configure my CS8000 with it's typical 20 -odd birds, transfer the channelist and software to my pc, Clear out the CS8000 with the Clear_HD bin file, and then reload my custom channellist/software combo. Everything is restored. There seem to be no gotcha's , although, perhaps saved points in Diseqc 1.2 mode might have to be resaved, but all the many menu buttons to set up each bird is out of the way.
I've also asked for a Factory file in this new format, with the addition of the two missing ku birds.
Can I pick up vertical signals with 36" directv internation dish?
newbie question - dish
