any way to get tv2 on 625 dvr lower?
Not really.
The times I've needed TV2 to be on a lower channel number I either (a) ran things thru a VCR and outputted things (keeping the VCR on) on either channel 3 or 4; or (b) I swapped TV1 with TV2 and used the RCA jacks of TV2 into the television next to the receiver, and then used TV1 outputs to feed to the distant television (had to use two UHF remotes in this instance)
If you put the recievers modulation output to "Air" mode instead, you can reach most numbers below 70, or you can do like the previous post and put it through a vcr. Why do you want it that low? Usually worse quality.
Darrin
Ocala DRS
for anyone else with this same need, and no old vcr laying around... a cheap RF Modulator does the same thing without having to have a vcr
HD-only pkg subscribers.. what happens in Aug?
HD's on 110 Spotbeamed?
