>>>I have some more questions for you if you don't mind.<<<
Sure!
>>>>1. Did Crave Electronics contact you before the install date to confirm the install or did they just showed up the day of the actuall install? <<<<
My husband called them on Thursday to confirm.
>>>>2. Did you have your diplexer installed or not? <<<<
Nope (see lower on in the post).
>>>>3. How long did the actual installation took?<<<<
>>>4. Did you get all the Local OTA's or did you encounter any problems? also is the Stealth Antenna good enough or did you have to upgrade? Did they install the antenna together with the dish? <<<<
About two to two 1/2 hours or so. It was a little tricky to get the line of sight. We have a lot of trees, but that wasn't the problem. There is a tall tree about 2 blocks away that was causing a problem with getting the signal, so the installer moved the dish and pole mounted it to a ham radio antenna on the roof left over from the people who lived here before.
The Stealth antenna is mounted separately off a roof overhang.
Both are working well with this arrangement so far.
The sat signal has been usually upper 80's - low 90's (post software update numbers), and the OTA is upper 70's (better than I expected). Occasional breakups on the HD channels but way better than I had w/Comcast. All of the expected digital locals are getting received okay (see my note below about 31-KMAX).
>>>5. Since I also have DirecTV right now installed on my cable wires running throughout the house, I'm wondering if the installers will create a seperate hole in the wall for Voom's to go through? Will they charge extra for that? I'm just wondering if you had the same situation.<<<<
We had cable and one existing line into the house. Crave wanted to originally charge $80.00 for the separate OTA line, but we got it resolved through Installs Inc before the install took place (and even through I didn't originally see it because I checked my Yahoo acount too late, I also received email from a representative at Voom corporate early Friday wanting me to call so they could help resolve it also as Wilt H. saw my post about it on the Yahoo group).
We ended up re-using the existing cable wall plate (and RG6 internal coax which works fine) for the dish and a new line and wallplate was installed for OTA w/ no charge.
The installer they sent was really great (and a really nice guy!).
** Note: You will be missing KMAX UPN (31) as it's not mapped yet. The bonus part of having a separate OTA line it that if you use a high quality spitter you can split the OTA line before the box and send the other end to your VCR to use as an analog tuner (which will be the only way to get 31 right now). Analog only notes --> The analog 31 and 58 (KCQA) don't come in great, but I'm pretty sure you're familiar with what they generally look like here anyway even via cable or sat
. 40 (FOX) comes in fantastic where I'm at. 10 & 13 are okay. 3 & 6 are pretty bad. YMMV depending on your location.
I'm doing this so I can both see 31 if needed (don't really watch it much, but good to have available) and also to be able to tape The Simpsons off OTA and watch something off the Sat at the same time.
*** Additional note: For SDTV I'm doing the same as I did with Comcast and the Moto 5100 box, which is running out a separate S-Video line from the box into my S-Video switcher (Sima SVS-4). If you can do something like that (S-Vid or Composite), you might find the SDTV channels much nicer looking. The black levels for SD and HD are different and the SD channels might look pretty washed out (via component or DVI), or at least they do on my display, so S-Video works much better in our case (but again, YMMV).
>>>That's all for now, thanks for your patience and response.<<<
No problem and hope it helps!
DeeAnn
