My digital channels are at 180 degrees. Rather then paying for an expensive 360 degree antenna, could I parallel 2 cheap UHF antennas using a splitter? One aiming south and one aiming north? My DT channels are only 2-11 miles away.
Yes 72 should lock but I do get pixlation now and then using the Dish Vip722 tuner
Thanks Roashru, they are in my attic. I aimed using the guide I found on the net showing where all my stations are. I fine tuned as close as I can get them.
I aimed one antenna SW where 2 of my stations are then should I connect with flat cable to the other antenna aiming NE then install the flat to RG adapter on the NE antenna with the RG6 down lead? Now they are connected with RG to a splitter
I think 72 is as high as I'm going to get. weird though the tower is 3.5 miles away
